Found in the manual how you adjust it. Since I'm running rich I guess it is the main fuel adjustment screw I need to turn in. Now this tractor doesn't plow anymore. All it does as far as working hard is mow grass with about 2/3 to 3/4 throttle. When I drive it over to my Uncles worm farm to mow I'll open it up in 5th gear. But other than that, that is all it does.
So with that in mind, how should I go about adjusting it since I'm not going to be putting the motor under full load.
