TractorLinks.com
Show Parts for Model:
Re: 756 won't move or steer in very cold weather
The tractor vet
02-09-2018 08:42:34
Yep Delta Nailed it the 17 gal pump is sucking more then the 9 gal and the 9 gal is getting on the weak side . Plus you have some water in your Hyd. system and the ice cristles are blocking the filter a bit . You probably don't run the tractor hard enough often enough to cook out moisture . and the seal on the pick up tube is probably sucking air also . Now there are two ways to solve the air sucking , one is tear the tractor down and replace all the seals on the suction side , always replace the gskt on the hyd filter and make sure that the filter housing is FLAT at the bolt holes , Or just dump in five extra gallons once you are at the fulll mark . Next find one of them Allied filter extension housings and add a second Hyd filter . Then and only then can you flow enough oil thru the filter . Or you can BUILT A Cozzy warm tractor shed and keep your toy inside where you keep it 70 degrees . Then all your problem will go away .
