TractorLinks.com
Show Parts for Model:
Re: 756 won't move or steer in very cold weather
Janicholson
02-08-2018 20:39:28
Over filling it by 5 gallons might help prime it (after changing the filter). Jim
The tractor vet
02-09-2018 08:56:26
 Re: 756 won't move or steer in very cold weather in reply to Janicholson, 02-08-2018 20:39:28
On his sounds more like he needs to change his oil more often along with reg filter changes . If you do not run them hard often to cook out the moisture you can not believe how much water will collect in the large frames in short order . With me i stopped running hy Tran ( yep go ahead and beat me ) , the reason why is Hy Tran will suspend water and the filter is suppose to filter it out . well that is all well and GOOD BUT the filter will plug fast and ok so you change the filter if there is a lot of water in the fluid the filter will plug again in short order FAST . I have seen around here on systems that had milk shake or coffee with cream colored oil that just dumping out twenty gallon in the drain pan and putting a new filter in and running it in less then and hour the oil is milky again and maybe after a dozen or so filters it will Start to clean up . Buy not running hy trans and not usen the tractor that much one can get under it and crack ALL the drain plugs and let her drip dry BEFORE starting . BUT IF someone just bounces in the seat and starts the tractor all that condensation gets sucked into the filter and it plugs off fast and the bypass screen opens and then the rest gets mixed in to the oil and now you have coffee with cream once again . I go thru this every year with my friend and i get to here him whine about the cost of changing the oil when all it would take is for him to just crack the drain plugs and let them dip till ya see oil coming out before start up.
