guys few questions: have the differential rebuilt and installed along with both sides on the drive line minus axles as working on some other things.
this tractor had the lower aux fuel tank and I am not putting it back on, what's a good way to plug the line for the top tank going to the bottom tank?
anything else I need to do to the top tank? is there a sending unit or do I need to get that. the lower tank if some one needs I will get rid of cheap.
I still need to get a 5401000 pto unit to replace the 1000 one that was on, witch coupler do you modify on the shaft inside the tractor? there is a place about a hours drive that has some pto units rebuilt. I bought a new hyd pump and have it installed and going to send the one that came out to be redone as that will fit some of my other tractors.
one other question what is the right color black for the under fender and behind the fuel tank, some stuff I will paint while its apart but the rest of the tractor I will paint later when I have all the bugs out. I will be using automotive paint with hardener.
thanks for the help.
