Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Super m 12 volt conversion
used red MN
02-07-2018 10:32:24
Use Charlie’s diagram for 12v coil H-M, sounds like your replacing a mag with a distributor. Get you a 12v coil that does not require an external resistor. The only variations are that the 10g wire shown connecting to the amp gauge will connect straight to the ignition switch. The wire feeding the light fuse will also connect with that wire at the ignition switch. Then you just need a wire to feed your volt meter on the on-off side of the ignition switch and the other volt meter terminal goes to a GOOD ground. Be aware his diagram refers to diode plug that is part of the harness he sells. A diode or marker bulb must be wired into the terminal 1 connection at the alt or your tractor will continue to run off power produced by the alt after you shut it off. I also would recommend a 30-40 amp fuseable link wired in at the power pickup point from the starter switch. That way if something shorts it burns that out instead of all your pretty new wiring.
