TractorLinks.com
Show Parts for Model:
Re: Farmall A clutch
Olliejunkie
02-06-2018 20:44:17
Thank you. I think I checked the splines and slid the disc on it. I may have missed it. The only thing I didn't check closely is the pilot bearing. Just had a quick look and it looks like the pressure plate is moving plenty far.
Janicholson
02-06-2018 21:01:00
 Re: Farmall A clutch in reply to Olliejunkie, 02-06-2018 20:44:17
If the driven disk was tweaked a bit when closing the split, it can drag due to the friction material touching the Flywheel or Pressure plate. The pilot bearing is also a possible friction point. Driving it by putting it in gear clutch down (clear assured distance to stationary objects.) and driving it around using the clutch often in 3 and 4th gear. Jim
