Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall A clutch
Olliejunkie
02-06-2018 18:47:39
I just put it together so it should not be stuck. I tied the clutch pedal down, put it in forth gear and turned the hand crank. Tractor did not move. Put it in first gear, turned crank and tractor moved. When I get some tires I may just drive it and let it burn in.
Janicholson
02-06-2018 20:15:01
 Re: Farmall A clutch in reply to Olliejunkie, 02-06-2018 18:47:39
If the clutch shaft splines are worn (even a little) the clutch plate (in a different tractor/engine clutch combo) will hang on the shaft and cause it to be pushed into the flywheel. This drags the disk at engine speeds, causing the trans to grind. It may be necessary to polish the shaft to eliminate steps or burrs on the splines. Jim
