Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Fixing up an IH AOS-6 made in Australia
Michael QLD OZ
02-06-2018 17:03:42
I am trying to get ready to fix up an AOS-6 (Australian Orchard Special) was a modified W-6 with an AC-248 engine. Introduced June 3, 1953, it was built until July 1959.
I can find some info on the Tractor, but have had no luck so far sourcing an engine manual for the AC-248, any suggestions as the engine is very seized at the moment.
Michael QLD OZ
02-17-2018 02:48:34
 Re: Fixing up an IH AOS-6 made in Australia in reply to Michael QLD OZ, 02-06-2018 17:03:42
I finally got back for another look at the tractor. Ive never worked on a magneto before, any tips?
athol carr
02-08-2018 00:18:40
My copy of the owners manual show that the standard was distributor ignitions, standard kerosene AC248 engine.
Redturbo
02-07-2018 23:33:40
I got out my IH Geelong Works book by SJ Galloway. Forgot a lot of the info in the book. The first Australian tractor was made on April 15/1948. On the grill is the IH emblem like Super's over here have, so they came out with that 5yrs earlier. All Australia built tractors from 1948 to 1965 that ran on Kerosene use that manifold. So the manifold in question is correct for a tractor built there. Orchard tractors built from 52 to 59 use the AC-248 engine. No info is listed about when cast tub change to frame rails thou. Rear tires(tyres) are 13 x 26. Fan shroud is deeper, cast iron oil pans, aluminum serial tags are some of the differences. The Super AW6 got the bigger engines like ours.
Michael QLD OZ
02-08-2018 00:20:46
 Re: Fixing up an IH AOS-6 made in Australia in reply to Redturbo, 02-07-2018 23:33:40
Thank you.
the alloy tag is hard to read but I believe the numbers are:
AOS6 SAOS6503
1595
athol carr
02-07-2018 13:16:46
The AOS-6 had the same engine as the AW-6. the three point cylinder is horizontal fore and aft under the top of the transmission cover. the hydraulic pump on the early ones, at least, was the Farmall M pump behind the clutch.
Michael QLD OZ
02-07-2018 13:09:55
I only have online pictures to go buy, but the 264 inlet manifold seems much smaller than on my tractor
Michael QLD OZ
02-07-2018 13:03:36
can any one suggest a visual difference between the 2 engines?
John M
02-07-2018 05:02:56
I dont have my books in front of me, Ive stored all of that, but it should be the same as the AM engine, but Im also wanting to say you should have the "Super" 264 engine, not the 248, but I could be wrong on that. Cant recall the change over date.
Redturbo
02-06-2018 20:24:55
Some of that looks like a SW6, same emblem on grill, same frame rails. But rear half looks a lot different, rear rims & the 3 point hitch! That's so cool, wish tractors of the era that were built south of the 49th had that. What size are the front rims? Assuming the tractor has a belly pump to run the 3pt hitch? Never seen one of those on an orchard or W series tractor over here. Binder books is great place to get manuals from, that's were I get them from.
Michael QLD OZ
02-07-2018 02:11:24
 Re: Fixing up an IH AOS-6 made in Australia in reply to Redturbo, 02-06-2018 20:24:55
SW6 is the American made version of this Tractor I believe.
tom dowling
02-06-2018 17:29:42
pretty sure that's the same engine as in a "m"
Michael QLD OZ
02-07-2018 02:12:32
 Re: Fixing up an IH AOS-6 made in Australia in reply to tom dowling, 02-06-2018 17:29:42
Does that mean the M series had an AC-248 engine in there? That might make getting a manual for easier.
rustred
02-07-2018 14:38:30
 Re: Fixing up an IH AOS-6 made in Australia in reply to Michael QLD OZ, 02-07-2018 02:12:32
post the serial # or pic of it. that tells lot of the story.it will also tell you if its the super model. those super tractors hit the end of the line in 1954. plus this one has the distillate shield on the manifold. no super model had that. plus the supers had the 264 engine and some could be 281 as i have one. it has the channel frame like a super. and has the super emblem. brakes should be disc not band also. exhuast should not be going through hood on an orchard model. lots of parts may have been added to this tractor from other w6's. who knows. i do know the governor throttle lever coming out of governor housing is not the same on an M. M is down w6 is up. are the rear tires 30" or 26" , they look like 26" the fronts on super's have a different hub. this one has weights and appears like the standard hubs. but yes get a serial # and go from there. you will need it also when looking for info.
Michael QLD OZ
02-08-2018 00:22:43
 Re: Fixing up an IH AOS-6 made in Australia in reply to rustred, 02-07-2018 14:38:30
Posted above
