Bmiller12345678
New User
Guys,
Put a new head gasket on a with a super a motor. I torqued to
65 ft/lbs. before I started I filled with oil and when I added
water, it started leaking out the distributor side.
I pulled the head and noticed that the new sleeves were ever
so slightly higher than the top of the block.
Should I try another gasket and torque to 80 ft/lbs or try to
shave the tops of the liners down?
I made sure top of block grooves were clean.
Thanks
Thanks
