Bud Kaiser
I have a strange problem that happens to my clutch. My RT brake will lock when cold if not slowly applied but works fine after using it and when this happens I cannot shift tractor into gear (grinds like clutch not working) Last 2 times I adjusted T/A but this time adjusted and put back too original setting and all is ok T/A works and clutch works ( The Tractor has always moved the petal is almost let out at the top) I just don't understand the relation between locking brakes and the clutch. Any suggestions ? It has been doing this for awhile and as long as I do not lock brakes all works fine ?
