Dave H (MI)
I have a good running 1586 I use for tillage. Rear duals and a full set of weights on front. Anyone using/used a 1586 who can tell me what size field cultivator would be the max? Average soil, good topsoil with some clay in areas. Whatever is the consensus is the maximum it would pull, I will probably look for something about 2/3 that size. So if you tell me 30' I will look for something around 20'. I don't like to max out older tractors. Stuff breaks and then I have down time while I fix it. I should mention that any cultivator I look at is going to have straight tine harrow on the back end...no rolling baskets or anything fancy.
