I have an early C with battery ignition and a generator with saddle mount cutout / four position light switch. I don't know whether the distibutor was added later, neither my parts or operators manuals shows this combination. Actually, the wiring diagram in the parts book shows a regulator with the magneto, "special 501-47125" but under the generator section it depicts a Delco 1101355, adjustable third brush genny with cutout for that serial number range. In the operator's manual there is a section for starting and lighting equipment for tractors without V regulator and it mentions only magneto and relay. Conflicting info for sure. I know my options and tend to lean towards "original" but the problem here is what was original. If I keep it as is, does anyone know if a rebuild kit for the 1100501 will work for the 1101355. Is the adjustable third brush the only difference?
