Dean Olson
Hi Guys,
I have a 1954 stage 2 Super H that has the wrong carb on it. The choke is on the wrong side and the # on the brass tag is: 5098DC. I suspect it's an M carb. .
I have 3 donor carbs #'s: 361525R92, 356948R91, 357231R91. These will bolt up and the choke is on the correct side.
What little research I can find seem to point that these carbs are correct for 300, SM,& 400. This is per the carb rebuild kit #'s on this site.
I suspect I'll have to disassemble them and see what jets and Venturi they have?????
What size jets and venturi are correct for the SH/300?
