340 U steering
jay72
New User
My 340 U Gas has no assist with power steering. The rest of the Hydraulics work fine. This just happened out of the blue. Can anyone help?
Can you steer at all? I have a 350 that had no oil to power steering. I finally got oil to it, found a broken spring under 4 bolt plate on priority valve. Now have oil but little power. Only have 500 psi on test port. Maybe pump is bad. About ready to give up and send tractor down the road. Only way to steer is to lift front wheels off ground with bucket. No way to live.
It can be turned while moving but has no assist to speak of. Took gear apart and all seems well may have to look at valves under steering wheel.
