I was cutting dried pararie grass this afternoon with a #9 McC 6ft sickle mower. I had it in 4th and set mid way. It finally started heating up after around an acre when I was raking it with a McD Sulkey rake. I intend to use the grass partially as filler in raised bed taters, and partially to run through my 1950 Case 140 bailer when I get someone who can tell me why it dosnt tie.
Anyway, it started boiling over. The fan was turning great. QUESTION. I had the gas barely cracked open at the bowl. Would that cause it to overheat?
