urbancase
guys thanks for the input, I will plan on pulling right side first and will tilt cab forward and not pull it off. I have started removing the fuel tank brackets to pull it out and go from there. I had the top link bracket off when we were trying to see what was going on and the differential was spinning but no power to the tires. one other question I have is when we were testing this a few months ago the trany would go in all three gears and reverse but would not go in park at all. were would you start to fix that problem?
I will take some pics and post as a go along. need to mostly likely replace the brake disc in this when I have it apart also.
thanks
thanks
