JIM MALL
was having issues with tractor sputtering had some bad gas. pulled tank cleaned it andpulled carb put akit in it.the zenith carb has no adjustment ffor fuel.when tractor runs it runs rich like being coked.some times come out of it but only a few minutes.need some help.jim
I don't know that tractor as such but maybe try a bit of trouble shooting.
#1 make sure the spark at the coil wire and at all the plug wires is a good blue/white that will jump a 1/4 inch gap or more.
When was the last time you serviced the air cleaner?? It could be clogged up. You also might try running it with the air cleaner tube off and see if that helps.
Every one of the several of those that we had ended up with a similar sized Marvel carb. I tossed those chitty pot metal little Zeniths in the trash barrel. gm
