urbancase
rboots : I am no expert and would like not to have to pull the cab. when we tested it we could not get anything out of either wheel, the left side did act like it wanted to do something but never and that was holding the brake on each side. I post this problem earlier and some felt it was the differential, I am not sure myself, when I bought the tractor at auction they said it was being used and the guy heard a loud pop and stopped moving. this fall I hot pressured washed and there was a lot of oil coming from under the cab so I was going this route so a person can fix all the problems. and if it is the differential the only way I see to get it out is from the top. I may be wrong, and I am open for ideas.
while on the subject of the cab if I do take off what are the best lift points? like I said I plan to repaint when it back together. like I said feel free as I'm on uncharted ground on this, I do have a IH blue ribbon book on this. thanks
