826 3 point lever
RBoots
Hey guys, haven't used it in a while and haven't had a chance to look at it, but the lever that actually lowers/raises the 3 point will slowly drift down on my when using the tractor. Does it have a friction disc there somewhere to hold it in position, or is it a spring of some type? Does it have an adjustable tension to it? It used to feel fairly firm, but now just feels kinda floppy. The 3 point works fine, it just won't hold in position due to lever creeping down. Thanks!
Some had spring with the nut that you would tighten down on the friction disk then someone had a clamp around the shaft on the levers you were just tighten them to where you want the friction to be
