charlynn power steering
Irvb
Are there any knowledgeable people out there experienced in taking the charlynn power steering motor apart and repairing. I have a friend working on one and having problems with it.
Punch on the link. Then on the literature page that appears type "torque generator" in the search box. It will return a list of repair manuals for various models Charlynn steering motors. Select your model to download the parts/service/repair manual for your unit.
Charlynn steering service manuals
I just had one apart to replace the seals in it.
Here are the instructions I used for disassembly and reassembly: https://www.midweststeering.com/wp-content/uploads/207-Torque-Gen.pdf
Here is the link for the lowest priced o-ring kit around: https://www.midweststeering.com/product/seal-kit-for-s-and-207-series-torque-generators/
This kit has seals for two separate models so you may have some left over.
Keep in mind they are timed, you have 50/50 chance of guessing it, or read the instructions. If you are wrong you WILL know, because the tractor will steer like it's possessed.
