Ryan.T.Rebel
Hi I'm going to restore a farmall M as a first restoration project i would like to make it as close to original as possible but I haven't restored any thing before any tips or help.
Thanks Ryan
Thanks Ryan
(quoted from post at 09:25:15 01/22/18) An M is a simple tractor to 'restore'.There are a 'bazillion' parts out there. Since this is your first 'restore' don't be surprised or be discouraged if it not perfect. Few actually are.there will be room for improvement on the next.Perfection takes practice.Also,If there is anything special,or something less common,leave it.Homemade 'options'/equipment/mods are especially interesting. Clean it up if needed,but leave it. It's a lot more interesting to look at than the same old same old 'perfectly' restored old tractor.Pay attn. at the next tractor show you go to. See which tractors get the most attn.The perfact ones,or the ones that are a bit different.
(quoted from post at 17:52:04 01/22/18)
How do I get the right color and the right decals and that kind of stuff or will that be in that book
(quoted from post at 16:37:18 01/22/18) NEVER KEEP
TRACK OF THE DOLLARS. Save the reciepts but never add them up. And never let anyone else see them.
And enjoy your nice M every time you run it.
(quoted from post at 00:30:21 01/23/18) How many coats of paint do I put on i was thinking about 3 does that sound good ?
(reply to post at 10:16:59 01/22/18)
(quoted from post at 04:05:00 01/23/18)(quoted from post at 00:30:21 01/23/18) How many coats of paint do I put on i was thinking about 3 does that sound good ?
You follow the instructions for the paint you select.
(quoted from post at 14:11:23 01/25/18) Well, not bad I guess but the intake pipe and starter should be red, the rear axles flat black or unpainted and the seat should be silver duck
canvas over foam cushion. Sorry, but these comments are to help you, not to be overly critical. And regardless, it is a nice looking tractor.
lease submit pictures of tractor and rims. There are some real experts here who after viewing your rims and tractor can give good advice on fixing things and what to do next(quoted from post at 13:47:04 01/31/18) Does anyone know where i can get rims?
(quoted from post at 11:15:56 02/03/18) The tires look ok but the rims are rusted out
(quoted from post at 08:16:55 02/03/18)
This is the only photo i have of it it is at my grandpa's house and i haven't been over there to get a better photo
(quoted from post at 16:25:33 02/09/18)(quoted from post at 08:16:55 02/03/18)
What is the other Farmall in this photo? Is that a B? The rear wheels look unusually small in diameter.
