VA injection pump help
mmidlam
I would like to try dissembling and welding a cracked VA pump housing before converting to a newer pump. I have Internationals pump repair manual
Can I get by without the special parts holders/organizers the VA repair manual recommends?
Nope, second gen Dodge-Cummins uses the much larger P7100 inline Bosch with the RQV governor. NOT what your Deutz needs for farming. Bosch A size pumps are made in 1000, 2000, and 3000 series. Most early Deutz use the 1000 that has the 17MM camshaft. Later Deutz has the 2000 series with the larger 20MM cam drive hub, like later Case and JD use. Cummins 5.9 can have one of several pumps, CAV DPA, Bosch rotary VE, inline pumps are Bosch A, MW, P, and P7100.
