Model B tires
We have a Farmall Model B with a single front wheel. The tire is so bad we can't even get the size of the tire. The last two numbers look like 12 suggesting a 12" rim. Does anyone know the correct tire size? And does anyone have suggestions about where to buy a new (or used) tire?
Thanks,
Here's what the parts catalog says:
FRONT WHEEL (non-demountable) ("B" and "BN") (standard), 6.00 x 12
Miller Tire in Ohio or Indiana sells any ag tire you need. Just Google "Miller Tire". Not cheap, but it will be what you need/want.
LA in WI
7.50x12. any tire store that sells farm tires can get one. Some forklift tires fit. also Gensco aircraft tires can probably help you out with a used airplane tire.single fronts are quite common in furrow irrigated country.
