I?ve pulled the steering assembly a part on this tractor. The housing was dry and the seal around the worm shaft had gone bad. In the process
I?ve removed the entire assembly. The IT manual indicates this can be rebuilt by pressing off the bearings and the worm gear. Does the upright
on the steering worm wheel shaft go completely through the assembly? I?m assuming so, and therefore that is the location press out the
bearings and seals. My concern is supporting that assembly during the press. I?m attaching a photo that shows a crack in the bottom plate
adjacent to the wheel stop. My thought is that this is what I support to press against. I believe I have found a replacement for it, but before I
get too far down the path of destruction, I?m asking if anyone has pressed these apart and suggestions.. Photo of the assembly and the crack
plate are attached.
plate are attached.
