Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Farmall H hand clutch
Brian Williams
01-13-2018 21:41:27
Are there different models of M&W hand clutches for the H? Mine has 4 fiber plates instead of 3 like the literature shows.
kevinj54
01-14-2018 08:50:24
 Re: Farmall H hand clutch in reply to Brian Williams, 01-13-2018 21:41:27
Some parts are the same.
The power transmitting parts will not fit.
Brian Williams
01-14-2018 08:31:11
Are there any interchangeable parts between the Hand clutch for the model H and the M? Could my 1951 H have M components? If so that would make a great unit for it.
kevinj54
01-14-2018 08:23:12
There is no way to add a disk, it would add about 5/16 to a device that has maybe .050 extra space.
Probably like the M and early ones had 4 plates.
kevinj54
01-14-2018 08:21:40
Can't speak for the H but the first year for the M had 4 disks and later units had 3.
D Slater
01-14-2018 06:18:32
Good question, bought 3 M rears with hand clutch from salvage yard many years ago and already had another. One had the extra disc, think I ask about it on this site at the time and was told due to wear another plate and disc was probably installed. When I compared units, the one with 4 discs had a shaft made different that went in the differential and a couple of other parts different that I can't remember now. Never found a definite answer.
Brian Williams
01-14-2018 07:56:07
 Re: Farmall H hand clutch in reply to D Slater, 01-14-2018 06:18:32
Seems the unit is a little longer than some of the pictures I have seen before. Judging from the internals it was made with four fiber plates. Unless someone bought an extra fiber plate and an extra steel plate to put in. Find that unlikely.
