TractorLinks.com
Show Parts for Model:
More Horsepower
Farmallpuller03
01-12-2018 16:15:42
I need a little help... I'm pulling a 1941 Farmall M, I have a turbo on it and i was wondering if there is anything else i could do to get more horsepower?[/b]
kossuth
01-19-2018 01:17:35
 Re: More Horsepower in reply to Farmallpuller03, 01-12-2018 16:15:42
There is alot you could do. Areas where power can be made.
1. Convert the entire valvetrain to roller
2. Custom grind a cam for the motor
3. Fuel inject the motor and work on injector placement onto the back of the intake valve.
4. Port and polish the head
5. Lighten the rotating assembly
6. Intercool your existing turbo setup
There is alot you can do, just depends on how deep your wallet it.
High octane
01-17-2018 22:18:37
Convert it to alcohol. Dial in your ign.
JAsher452x
01-15-2018 11:35:44
it all comes down to how much you want to spend and what are the limits to the rules. since you already have a turbo, I would build an intercooler. a small intercooler and an ice box with a 12v pump to circulate the chilled water.
Another option is to change fuel. I know I will catch some grief for this but, get another carb and build it to run E85. It has an octane rating of 105-110. it will drink about twice as much fuel, but you can throw a lot more boost at it and will lower your EGT on your turbo.
Just my two cents for more power with what you already have
Dave S.
01-14-2018 09:25:12
With a turbo I think it would make more HP using the low compression distilate head and pistons. Leaves more volume for fuel mixture and compression pressure would still be good.
mattwillson
01-13-2018 03:32:15
LP head , adjust waste gate to 15psi boost, 100 octane gas. Only issue would be traction.
David G
01-12-2018 17:04:16
Nitrous Oxide, hold onto your hat.
ihtimmy
01-12-2018 16:55:12
The old boy I started to work with in 76 his name Willy he show me make a m and sm and 400 and 450 run we install m&w pistons and liners lp Head he drill Governors weights with 3/8 drill Bit new gov spring on the carb he would used a 806 venture and main Jet take the muffler and knock the baffles out of muffler or a straight pipe we did things to 460 and 560s same on 656s
