Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
M - Camshafts
ncarolinasailor
01-11-2018 10:25:38
I got the motor emptied so I am going to clean it up and start putting it back together. Cam then Pistons/sleeves then Crank and Connecting Rods sound right? I need to replace the camshaft as it has some sever rust on the journals and I buggered the threads getting it loose and out. In any case, does it matter which # camshaft I put in it. It's a kerosene head so if I can get any improvement with a different camshaft I would do that but I know nothing about the #s I would be looking for. Thanks!
nosih
01-12-2018 15:43:58
 Re: M - Camshafts in reply to ncarolinasailor, 01-11-2018 10:25:38
I have NOS ones available
mbfarmall450
01-11-2018 13:39:33
I have some used ones 734-915-2543 Matt
rustyfarmall
01-11-2018 10:34:00
A camshaft for a 450 will be the best you can do, but any of them for an M through 450 will fit.
ncarolinasailor
01-11-2018 10:37:44
 Re: M - Camshafts in reply to rustyfarmall, 01-11-2018 10:34:00
Any idea what the # is on a 450 camshaft? I am assuming the diesel cams don't work.
D Slater
01-11-2018 11:46:11
 Re: M - Camshafts in reply to ncarolinasailor, 01-11-2018 10:37:44
Latest cam for those engines was the only one made after sometime in 1957. Regular replacements are supposed to be patterned after that camshaft. You will need the nut for it also unless you already have the left hand thread one. If getting used it may have more than one number on the cam itself. One with suffix DB after the number on it is what to look for. New ones should say replaces a suffix the same or DBX if nut was included. Gas and kerosene used the same camshafts so a good one for any model will work. Think I recall 48196DBX being the replacement number but don't hold me to it. Probably show new ones on this site. M to SMTA used the D suffix. 400 and part of the 450 used DA suffix.
ncarolinasailor
01-11-2018 12:27:49
 Re: M - Camshafts in reply to D Slater, 01-11-2018 11:46:11
Awesome, anyone got anything laying around?!
FastFarmall
01-11-2018 12:52:33
 Re: M - Camshafts in reply to ncarolinasailor, 01-11-2018 12:27:49
Cam and lifters got to come together.
