TractorLinks.com
Show Parts for Model:
Farmall 560 weak hydraulic
garr806
01-11-2018 06:30:27
Been having problems since I got this tractor with hydraulics. I replaced the hydraulic pump with a 17gpm pump, replace the suction tube and seal between the pump and the filter. Replaced the O-rings in the valve stack. Removed the safety/regulator valve clean it and inspect the orifice and clean it as well. When it runs I have to rev the tractor up to get the loader to move and it will move slow and it will shutters while raising it up (loader cylinders have been rebuilt). When you put the lever back into the neutral position the hydraulics will make short continuous squawk noise. Rev the tractor to an idle it will go away. I assume my problem lies with the safety/regulator valve that something is binding.
hayfarmer
01-11-2018 10:53:31
 Re: Farmall 560 weak hydraulic in reply to garr806, 01-11-2018 06:30:27
you don't mention changing hydraulic filter. When I got my 560 previous owner said there wasn't a hydraulic filter so mine was full of stuff that looked like you might find in a baby diaper so it took a couple changes to clean up system. I also had to change hydraulic pump. I put a new spring in the safety valve hoping to boost pressure a little. There were several types of hydraulic filters used in those at different stages if you haven't checked that out.
Roger Tomfohrde
01-11-2018 07:02:26
I have been told to run the tractor and rotate the single to double control between the clutch and brakes slightly and see if it goes away. There is a pilot passageway in the valve that may not be in alignment. I have not tried it yet as I parked mine till spring to see if it works.
