I've install a 1.25'' oil pump on our 1086 2 years ago to solve low oil pressure at idle, when I installed the balancer it would not go into the seal housing enough to keep it from seeping oil, I have since read somewhere that there were 3 widths of oil pumps used on the 400 series engines the 7/8''& 1''were used on the B engines and the 1.25'' was used on the later C engines, the 1.25'' from what I gather can be used on the B engines but the balancer has to be machined to accept it, and possibly and over size sump tube installed, does anyone have info. as to what changes were make to use the larger pump and possibly photos of the upgrades, this tractor was bought with a bad oil pressure gauge after finding that and that the oil pressure would barely move off 0 on a mechanical gauge at hot idle, 35 psi full throttle, I swapped out the relief valve no change, then I replaced the pump it had a 1'' pump no change, so I dropped the pan replaced the bearings rods didn't look all that bad and the journals measured to factory new tolerance, mains were worn and one had a wide grove that appeared to have been washed across it, but the best I could measure the journals the were also to spec,i double checked then with plasti-gage it showed the same, I checked the cooling nozzles they were good, even with all this and the larger pump I have 15 psi at idle hot 50 psi at anything above 1/3 throttle, I suspect the cam bushings are part of the problem but that's a major tear down which I don't want to get into as long as it starts and runs as strong as it does now unless someone can tell me what I missed, if I can fix the leak I going to run it like an old Detroit diesel, high volume low pressure until it gives up, thanks in advance for any info on the low pressure problem or pump size upgrade
