IH 1486 steering problems
beef88
I've got an early 1486 model that I'm having trouble with the power steering. When the tractor is cold or going down the road it's almost like the steering wheel locks up for several seconds. I've replaced the obvious first, the hydraulic filter. Where should I start at next, MCV pump?
Thanks
Overfill the Hytran by 5 gallons to see if the added oil solves a suction leak that is pretty common in big frame IH. It is a cheap attempt with pretty good chance of a fix. Jim
