Johnnykick
I'm thinking of buying this tractor to restore. The guy tells me it's a 1956 Ford, but my research is telling me it's a 1954 Farmall 100. He says it runs and wants $350 for it. I need some help with identification and if anyone thinks this would be decent tractor to fix up and use in parades, etc. Here's what I've found:
The data plate on the left side is: "566 J"
On the right side, under the #1 plug there is no stamp on the flat surface. However, down near #3 and #4 just above the Firing Order 1-3-4-2 there is "C-123" in cast and just to the right stamped: "10621"
Under the Firing Order there is a cast "2"
Behind the oil filter: "3S49898 R3"...hard to read
The Battery compartment has: "354353 (or 8) R1
Thanks.
Johnny[/img]
Thanks.
Johnny[/img]
