Super H Mike
I few weeks ago I posted about one of my Super Hs that wouldn't start normally, I had to keep the throttle fully closed in order for it to fire up, and no choke. When it did start if I tried to advance the throttle it would stall instantly...once fully warm everything was normal in running and starting. Well I finally had time today to get it in the shop and check it. I had asked for guesses as to what it could be. Someone had guessed the choke plate screws had fallen off, CLOSE, the choke shaft is broken ! Inside the carb hole that is, so the lever and rod looked to be working ok, even had the normal amount of resistance, but the choke plate wasn't moving at all. Now how to repair it, braze ? , JB weld ? , or do one of you guys have one to sell me ? Thanks , Mike
