littlefarmer
Having a constant problem with my Farmall M not staying in 5th gear.
About 5 years ago, the 4-5 shifter fork on my M broke. So I go to the nearest salvage yard, pick one up, and install it.
I noticed after the install, it didn't quite move the 4-5 gear fully forward, when placed in 5th gear. So it kept popping out.
I go and get another used shifter fork. This one moved the gear somewhat closer to the transmission drive shaft, but still not as far ahead as it should, and still getting slipping out problems.
I have re-welded the end of the gear shift to specs. Replaced the detent balls and springs.
The internal teeth on the 4-5 sliding gear are in great shape. The teeth on the transmission drive shaft are ok. Bearings are tight, etc.
I am beginning to think that the vast majority of used M 4-5 shifter forks out there are bent. The reason I think so---is because probably 95% of these tractors have had the transmission shaft front pilot bearing go out at one time or another. And when this happens, the front of the transmission shaft wobbles and bends the shifter fork.
There isn't a lot of engagement distance on the teeth of this 5th gear. So if it isn't moved fully forward and held there properly, it will slip out of gear.
I really need to have a reliable fifth gear on my M, since I use it for farming. Any advice on what I should do would be appreciated. Thanks!
