449 vs 449A planter
449A should have the ability to checkrow plant without wire by means of a trip lever on gear box and rods controlling gates in the planting drops
If you have parts book and a couple years ago they were avaible for free on Messicks site you can see the differences. One thing is corners of frame are welded on one and bolted together on the other. Without digging out my books I think the bolted together is later thuss the A added to the number. Think that is the big difference but the books will tell you. Either one with a clutch lift is a high priced planter in Amish area as they are the only clutch lift planter that can be set on 30" rows and parts avaible. Optional disk openers more valable.
