First I-9 Found!! And it's a Diesel
Josh4520
<image src="http://forums.yesterdaystractors.com/photos/mvphoto8070.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto8071.jpg"/>
My uncle found this old girl while searching for parts for his 4 motor antique pulling tractor, "The Bossie Project.
The serial plate reads: IDCB501.
For more info, check out his Facebook page "The Bossie Project"
the fuel tank support with that serial number maybe worth more than the tractor. noticing it has rubber tires and hyd. lines appears odd to me for it being #1 in 1940. i had an I9 and it was on steel wheels.
(quoted from post at 13:11:20 12/25/17) the fuel tank support with that serial number maybe worth more than the tractor. noticing it has rubber tires and hyd. lines appears odd to me for it being #1 in 1940. i had an I9 and it was on steel wheels.
Good call on that one Rustred! I hadn't noticed it was #1 until you brought it up. I glossed right over all that stuff.
There is an I-9 at Jaeckels in Fort Atkinson, WI. May be enough between the two of them to build a tractor.
