farmallsandcoops
Went to the neighbors to have him weld some hooks on my bucket. Things went fine on the way over. Parked in front of his shop, he welded them in place and I got in to leave and clutch went easily all the way in, but clutch would not disengage -- transmission still spinning and I could not get it in hi, lo or reverse. Could start with it in gear. All parts are moving -- clutch pedal, clutch cylinder on flywall and linkages on the side of the transmission under the cab. With clutch pedal pushed all the way in, it would slow, but not stop the transmission. So we rolled it back from his shop so I could start it and get home. As I pulled around his circle driveway, I slowly pushed the clutch in and about half way and that allowed me to shift from high to low and also into reverse. So, am at a loss. Thoughts?
