SadFarmall
I have run into a problem with my F12 fuel pump. Many moons ago the rocker arm wore to the extent that the pump failed to work. The then owner remedied the problem by welding more material onto the rocker arm. He also added weld spots to each end of the rocker pin in place of the original circlips (I have managed to remove the pin). Unfortunately the amount of material added to the rocker arm is excessive. To remedy this, he added several more (home made) gaskets between the pump body and the engine block. I have been unable to locate a replacement rocker arm. Original AC part number was 855547. Original IHC part number was 23542D. Can anyone help locate a new (or good) arm or provide correct dimensions?
Many Thanks,
SadFarmall
Many Thanks,
SadFarmall
