SadFarmall
The starting crank shaft on my F12 was partially removed and also damaged by the previous owner. One of the few things I dislike about the F12 is the necessity to shift the motor back in order to remove or refit the starting handle shaft. In addition, the chance of finding original parts in Victoria, is almost zero. Therefore, I have made a modification. Today is the day to test the new version. The original relationship between the starting dog/ratchet and the starting handle pin has been maintained (90 degrees). The universal joint is for Farmall H or M. The universal will be secured by a roll pin, for which a special removal / fitting punch has been made.
I hope it works!
SadFarmall
I hope it works!
SadFarmall
