Cleaning the carb on my Farmall 300 and noticed there is some play in the throttle shaft. I don't have a dial indicator (yet) but I would say .005". You can feel it but there is almost no visible movement up and down. Should I replace the bushings? What is the best way to get at the bushings since they are in almost blind spots? I guess if I would remove the end plug I may be able to knock them out, but there is not much "meat" of the bushings exposed to get at them. Where is a good place to get them? I checked McDonald carb but it appears they changed the website and is a little harder to navigate. I haven't found them. I found the throttle shaft but not the bushings.
Thanks in advance,
Brad
Thanks in advance,
Brad
