I’m visting my father in law in Minnesota and he purchased a 460 and loader to help move hay. Tractor is a real sweet heart she runs great and steers great. T/A is good. When you get ready to put the tractor in gear you can can either grind it into gear for probably 5 minutes or shut it off and put it in your desired gear and start again. The clutch is at the very bottom 1-2” of the pedal. If you barely let off it’s moving at full speed for the gear. I’m thinking the cutch needs to be adjusted? We have ordered a manual but it won’t be in until I’m back southern Indiana so I can’t read a manual and do it. If anyone knows what’s wrong or if it’s adjusting the clutch can you describe the process on a 460 please?
The tractor has a really nice Du-Al loader on it that works pretty decent. When the loader is just resting (not being used) I keep hearing a chirp from the hydraulic pump ever 5 or so seconds. Sometimes it’s faster sometimes I don’t think it’s even doing it depending on where the loader is. I think it may be low on oil. Where should I look to see the level and if it’s low what does everyone recommend to put in it? Or is this a different problem. The loader is being run on the hydraulic sticks on the right side of the dash (orginal equipment levers).
Any help would be appreciated. It’s not a John Deere or a Massey so I’m a little out of place on this one. Thank you guys so much.
