Farmall M wide front end hubs
Heifer
Hi! My front rims are rusted on my M and the rims are welded to the hubs. I have hubs from my old narrow front end, but they do not fit. Will hubs from a narrow front H fit? I have a good shop/friend that can weld the rims for me, I may go that route. Has anyone seen rims on an M like this? Thanks! Jake
<image src="http://forums.yesterdaystractors.com/photos/mvphoto7764.jpg"/>
A picture of the wide front axle would help.
Someone might be able to identify it so you could look for parts.
Those are not Farmall wheels.
An H hub will fit an 'old style' wide,and some Norden/Swarts fronts. The wheels pictured are 'cuttoffs'. IH made solid cast wheels for H/M . that is what you have. Someone cut down the cast wheels and welded rims on.I have a set similar on an F12. Probably after WW2,when rubber was available again.
I agree with you Delta Red. I think the rims were welded on as well, the hubs are from a steel wheeled tractor. If H narrow front end hubs will work, I may go that route. I can get hubs and rims.... Thanks for getting back to me so quickly.
Here is the WFE. I hope this uploads
I want to thank everyone, especially DeltaRed for helping me with my hubs. I bought a pair of H hubs and they fit perfectly. Happy Holidays to all! Jake
