Super H Mike
One of my 53 Super Hs has developed a weird starting quirk. When cold, it will only start with the throttle fully closed and no choke. If I advance the throttle or choke it at all it will only spin and spin.. not even a pop, nothing. It is turning nice and fast like always (12 V) This is a new issue, it has always started great with a 1/4 throttle and full choke no matter how cold it is outside. Once it fires up now with closed throttle, if I try to rev it up at ALL, it will kill instantly. Same if I pull the choke at all. So I let it warm up at low idle and then everything is normal. It doesn't stumble or miss at all, and starts fine warm no matter the throttle position. Heavy loaded it never starves for fuel, but I gotta believe it is fuel related. It started acting this way about 2 months ago. I plan to check it out and fix it soon, I wanted to throw it out to you guys for your best guess what makes it do that ! Thanks, So far I haven't touched a thing on it or checked anything.
