Disk leaves a crown
bass
My fast hitch disk is leaving a crown
There is a way to adjust
Do I need to take or lower the prongs
Here is a picture of the adjustment brackets
Bass
Thanks, that's what I was looking for. to rase or lower the prongs. Went and got new bolts
Had to cut two off. Will try rasing the prongs.
Bass
Have you tried removing the two pins on the sockets the prongs slide in? If set to float up and down when the wish bone is lowered enough it should help.
i did as you suggested and raised the prongs and it made all the difference in the world. the disk is now leaving a smooth finish on the ground. it this was late march and the sign was right , ide be planting some yellow dent
again, thanks
bass
