Power Steering Lines 350 Utility
Guys, I bought a power steering unit from a salvage yard back East for my 350U and replaced the standard steering unit. Does anybody know where to plumb the lines into the hydraulic system? My IT manual, owners manual, and the Case/IH parts site don't show where the lines go. Thanks for the help.
The steel lines supplying the PS come from the reservoir on the left side front and connect to the PS unit. The regulator safety valve (sandwiched between the Left rear "fast hitch" control valve and the reservoir. This regulator has the priority valve in it. This is not simple, and may require a doner tractor for all the parts.
I would use a PS pump from a 88ish Honda Civic. for direct Hydraulic pressure that is independent of the tractors hydraulics. A fabricated bracket and belt system is needed. Jim
