dcpky
He guys have a 1952 Super AV high crop doing in frame rebuild the old sleeves are 3/18 bore it has standard rod bearings the dealer says the sleeve deals are 28.00 apiece for the later model 8.00 apiece for early model Iam confused how do I no which ones to get I thought all 113 where the same Thanks for help also Merry Christmas
so you pulled the sleeves take the measurement of the sleeve where the o-ring goes that way you will get the correct ones what is the part # of the block that also is important it will be located near the filter cannister. You can get them on the parts area on this site as his preces ite be inflated.
As Gene says there are two different diameters at the bottom of the sleeve where the o rings go, 3 5/16 and 3 7/16. I believe the larger is the newer. YT, this site, has the 3 5/16 o rings at $4.23 each.
Dennis
size for earlier blocks is 3 5/16 but you could have later block which would be larger. There is a phone# for you to call just look for y-t tractor parts. NAPA can get them also
