I have a 1066 and need to flow test the hitch pump. What is
the best way to do a flow test on these tractors? I had the flow
tester plugged into the outlets and was getting 12 Gpm at 0psi
when I took it to 1000 psi the valve kicked out. Is that normal?
Do I need to tie back the lever so it won't kick out? I did check
the relief valve and by eye it looks ok. Any help will be great.
