D414 nozzle sleeve tool
CP1
If someone has the dimensions on the two tools to remove and replace the sleeves for the injectors? Given as FES25-13 and FES148-3 tool numbers. Or have you a way to get them out, that you have found to work? Thanks
My email is [email protected]
I found I can get them out tapping a few threads of 3/4 coarse and using a bolt and slide hammer
Going back in, I'd like to turn a tool on the lathe to drive them in square and proper
Thanks
That’s sorta what the removal tool looks like, 3/4-10 thread with a good taper on the nose to form the thread and drilled and tapped in the back for a slide hammer.
I have the installer sitting on my filing cabinet at home, I’ll measure it later.
(quoted from post at 22:39:44 12/18/17) Anyone dimensions or a picture of the tube installing tool?
The installing tool is going to be the same size as the injector. If you need an old injector I bet I could find you a few in my store room.
