Fan Removal
I have a 300U and I'm trying to remove the fan. After loosening the drive pin nut, the pin does not want to back out. I am correct that
this pin has to come out in order to remove the driver and the fan aren't I?
There is a nut you take off of the drive bar in front of the fan and drive the pin out, then the bar should slide off the shaft. Then take off the 2 springs and screw the drive pins and the other 2 bolts out and fan should come off. I think what you have loosened is the packing nut to seal water from leaking out the front of pump shaft.
