TheFarmallMan82
Hey all! Ive been restoring my 1928 Farmall regular and I've got it pretty much all apart with exception of the crankcase and cylinder sleeves. In the last post i had about the tractor I was trying to figure out how to pull the flywheel. Well I got it pulled with a puller I came up with using old iron from a cultivator and a 12 ton hydroponic jack. I will post some pictures of what I came up with. But right now I am having the issue with pulling sleeves. I do not have a sleeve puller or a lathe to make pucks to fit in the bottom of the sleeve. The ID and OD of the sleeves are as follows: F20/Regular-------4.110 3.740 noted from Nebraska Kirk in a previous thread. I have absolutely nothing to make these with! I have to pull them to replace the O-Rings on them and I need to replace one because its really badly pitted on the top of it and there is a very deep groove from where one of the piston rings rusted into place. If I could borrow one or have someone lend me one for a day that would be ideal. I would make them myself or have someone make them for me but I know of no one who would do it for really cheap... Anyways any help is appreciated!
Thanks guys!
Benjamin Olsufka
PS These pictures of the sleeves are before I cleaned up this area and took out the pistons to they look a lot cleaner
Thanks guys!
Benjamin Olsufka
