300 utility touch control
5 Forward
I have a 300 utility with a single hydraulic touch control that is leaking externally. Is there a rebuilt kit that can be purchased with all the o rings and springs or is someone out there that can rebuilt them at a reasonable price.
Is it the valve that is leaking and where is it leaking? There are o-rings that go in place when you bolt on a valve. If one is missing or damaged I do not think a replacement would be difficult to find at a good hardware or dealership.
I bet you could get away with replacing the 4 o rings behind the side cover and the 4 behind the valve to the reservoir.Mark
